Right so deffo leave the ones that are fine? Would it not make sense 2 replace all for fresh ones? Heads been reconditioned but in guessin they didn't replace the shims because the head rattles on idle
If the heads rattling it might be the inlet cam gear, they are sprung and need tensioning I believe.
If its not that then and they're in tolerance there's no need to replace them. They are just a solid disc of metal. As long as they haven't worn or scored then leave them be.
The inlet cam is gear driven off the exhaust cam (inside the rocker cover) . If you look at the inlet gear it's split and if removed without putting a locking pin in it moves and needs re tensioning
Ah right that's worth a look. So how do i check that n retension it. Sorry for all the questions guys. Never dun anythin to the head before
