aleximport25 Posted May 15, 2014 Posted May 15, 2014 hi there has anyone every had the fuel light come on and stay on even though I have half a tank of fuel ??thanks in advance alex. Quote
gorganl2000 Posted May 16, 2014 Posted May 16, 2014 check the connections to the fuel "level" mechanism/float/pump 1st if not, then check to see if its stuck/broken, but you would need to remove it from the tank Quote
aleximport25 Posted June 13, 2014 Author Posted June 13, 2014 riteo thanks mate i have a pop this weekend.i have noticed that some times the fuel light stays on even if i have a full tank but the i coud turn it off and on and the light doesnt turn on at all even if i ran out of fuel hopefully its just that simple. Quote
TimD Posted June 13, 2014 Posted June 13, 2014 Is the gauge measuring correctly and the light on, or does the gauge display an empty tank? Quote
aleximport25 Posted June 13, 2014 Author Posted June 13, 2014 The gauge works fine mate just the light. I could have a full tank and the light come on on startup then a few starts later it won't but it's also the same if it's nearly empty :s Quote
TurboTobz Posted June 13, 2014 Posted June 13, 2014 Common starlet fault... remove the bulb is the best option. Probably the sender has failed. Quote
aleximport25 Posted June 13, 2014 Author Posted June 13, 2014 yeah my old v had the exact same issue.rite well bulb out it is thanks alot peeps Quote
mikey4410 Posted June 13, 2014 Posted June 13, 2014 Wow u have seen what a fuel light looks like ?? I have never seen one work on any of my four. Lucky you. Quote
aleximport25 Posted June 13, 2014 Author Posted June 13, 2014 I didn't realise it was that common lol That's for the help guys Quote
