matthew ep91 Posted May 30, 2014 Posted May 30, 2014 My 98 glanza has abs but no abs light on dash . And i have air bag in steering wheel but no air bag light on dash ? Whats should i do , i have MOT soon lol Quote
akyakapotter Posted May 30, 2014 Posted May 30, 2014 Check it has bulbs in the back of the cluster I'd say abs has a problem that's why its light has been dissable and the same for the air bag Quote
matthew ep91 Posted May 30, 2014 Author Posted May 30, 2014 Ther is a bit of tape over the abs light ? What do u think i should do ? Quote
akyakapotter Posted May 30, 2014 Posted May 30, 2014 Test the abs system I'll find out how when I'm home and post here Quote
matthew ep91 Posted May 30, 2014 Author Posted May 30, 2014 The abs system does not work . If i slam the brakes the car will lock up Quote
daniel_g Posted May 30, 2014 Posted May 30, 2014 Check the ABS fuse first of all, you can also do a fault code check on the ABS system.Thats probably why a previous owner put tape over the light. Quote
matthew ep91 Posted May 30, 2014 Author Posted May 30, 2014 How has this passed mot before the ? Quote
akyakapotter Posted May 30, 2014 Posted May 30, 2014 How has this passed mot before the ?Back hander mot my abs is coming out before next mot has a fault that makes it come in asoon as I press the brake so main fuse for it is pulled. Quote
matthew ep91 Posted May 30, 2014 Author Posted May 30, 2014 But if the last mot was a fake . Y would the owner of put tape over the abs light then ? Quote
akyakapotter Posted May 30, 2014 Posted May 30, 2014 Not fake just blind eye to the abs light because it's well annoying with an orange light in your face I have one covering the engine management light lol Quote
oggy182 Posted June 23, 2014 Posted June 23, 2014 (edited) Just so you guy know, srs light is only a failure if the light stays on, if it dosent come on at all, you can only advise it. And the eml lights arnt a failure yet, it's supposed to be, but there's no option to fail it yet Edited June 23, 2014 by oggy182 Quote
Jhandy Posted July 8, 2014 Posted July 8, 2014 (mot tester) what oggy said is false, a airbag light or abs light has to light up upon start up for 1-5 seconds then go out, if the light does not come on at all its a failure jake Quote
