fiddlersport Posted June 2, 2014 Posted June 2, 2014 Hi require a quick list of parts to turbo the 4efe I have the 3 plug ep91 ecu and a set of the green injectors from a supra spare 5ef-he wiring loom which is very similar to the 4efte really depends on when i can find a person localish to do the wiring on the full 5e conversion but in the meantime i am missing the good old boost ! shall i give it a go ? Quote
GlanzaJ Posted June 2, 2014 Posted June 2, 2014 Right that post is very confusing! I thought it was wanted list and turns in to something totally different ! lool What bit's you need for your conversion then to put it plain and simple! Quote
5e colin Posted June 3, 2014 Posted June 3, 2014 right so in a p8 or p9 ?? wich gen 5efhe loom have u got ??? already sub comp neaded for bigger injectors !!! i think your better of keeping stock loom and ad your sub comp to that and remap richard will tel u more about that parts neaded 4efte fly and clutch and map sensor the rest can be done diy Quote
fiddlersport Posted June 6, 2014 Author Posted June 6, 2014 loom is from a toyota sera where the 5efhe engine came from, dont really know which gen but the car was a h registration if that helps basically turbocharge the 4e on low boost Quote
richardc9052 Posted June 6, 2014 Posted June 6, 2014 Then leave original 4e loom and buy a piggyback ;) Quote
