Hi guys, I unfortunately blew my engine over the weekend. At my local scrapyard there is an N/A Glanza S and the engine is perfect, cheap as chips too, I was wondering if I could just take that and add all my extras, turbo, manifold, FMIC etc. Also does the block have a turbo oil feed pipe?
Strip both down to a bar block and bolt everything from the 4efte onto the 4efe and it will be grand. Just run it on standard boost though unless you have a piggyback to have it mapped
i was running mine on standard bottom end, 1.9mm metal head gasket, turbo head, td04 at 0.8 bar, was running sweet till bottom end went (it had new shells when i bought it, but dont think they were sized correctly, so buggered it, done over a thousand miles on it tho. lol) but will be bolting up another 1 this week to drop back in it. doing this as temp running as i have an engine away for forging
