maddox710 Posted June 7, 2014 Posted June 7, 2014 Hi peeps i dont know how many of you guys suffer from problems with rear calipers, but mine seem to be binding a little i can pull the hand brake up and i sticks on. Im sure I've seen some1 on here re build there and use a special greese when re assembling them, can anyone enlighten me ? Quote
turbominicooper Posted June 7, 2014 Posted June 7, 2014 Hi peeps i dont know how many of you guys suffer from problems with rear calipers, but mine seem to be binding a little i can pull the hand brake up and i sticks on.Im sure I've seen some1 on here re build there and use a special greese when re assembling them, can anyone enlighten me ?rubber grease mate, pinky/red color. my mate rebuilt mine with axel grease and they gripped to fook. a strip down clean an rebuild is in order, only takes 10-15 mins per caliper Quote
maddox710 Posted June 7, 2014 Author Posted June 7, 2014 rubber grease mate, pinky/red color. my mate rebuilt mine with axel grease and they gripped to fook. a strip down clean an rebuild is in order, only takes 10-15 mins per caliper cheers dude, my job for tomorrow Quote
morgey Posted June 7, 2014 Posted June 7, 2014 You'll need new rubber gaitors as normal grease degrades the rubbers and causes them to bind. The rebuild kit from id works and camskills comes with some but it's worth getting a small tube of silicone grease (red stuff mentioned above) as they don't really give you enough Quote
morgey Posted June 8, 2014 Posted June 8, 2014 I've got 2 pairs awaiting a rebuild but i'm just slack Quote
