200sx-Starlet-Jay Posted December 11, 2007 Posted December 11, 2007 Ive been offered a Jap ecu for my uk starlet sportif, and it is a 2 plug fitment. I aint been and striped the dash yet to check, just wanted to know if anyone knows if they are the same fitment, also does it need anything else to run it.. i.e dangerous to just swap on its own?? Any help wud be greatly apreciated!!Cheers again peeps! Quote
Jozinobi Posted December 11, 2007 Posted December 11, 2007 Best man to answer this is Scutch0, Im sure he had a jdm 4efe ecu and tried it.In my opinion it will fit straight in but not run/start your engine due to the difference in looms perhaps and the immobiliser.The UK 4efe ecu is indeed a two plug.I'd wait for Rich to confirm all that.Joz Quote
scutch0 Posted December 12, 2007 Posted December 12, 2007 cheers joz.it depends what car it was taken off.i bought a 4efe jdm ecu that i believe was taken off a glanza s, which came with distributorless ignition, which didnt work.if it has come from a jdm starlet with the same ignition system as the uk spec 4efe it should work, but you will need to find out what size injectors the car it was in used, the glanza s had yellow injectors apposed to the uk spec green ones.the rev limit should be 7200rpm on the jdm ecu.the only other problem you may have is if your car has an immobilizer (which mine didnt) as jap spec cars generally dont have them. Quote
Nanglebadger Posted December 12, 2007 Posted December 12, 2007 me and jay could run into a few problems then by the sounds of things!Phil. Quote
Jozinobi Posted December 12, 2007 Posted December 12, 2007 Hopefully not Phil, but there is always that possibility.Im surprised it hasnt been tried and tested before, best of luck with it.Joz Quote
smythy75 Posted December 12, 2007 Posted December 12, 2007 the ecu starlet jay is lookin at is mine, it came out of a 92 n/a starlet and it has pink injectors! hope that helps a tad! Quote
GLS_mike Posted December 12, 2007 Posted December 12, 2007 I'd like to get an upgraded ECU but without knowing if it will work...is it worth spending the money and taking the risk. someone must have tried it!What ECU have you got atm Joz??Mike Quote
200sx-Starlet-Jay Posted December 12, 2007 Author Posted December 12, 2007 the ecu starlet jay is lookin at is mine, it came out of a 92 n/a starlet and it has pink injectors! hope that helps a tad!there ya go lads, now sort me out!! will that fit into my 97 uk starlet?? i dont have a clue if it will go in without any issues and dont know what wud happen if i just plugged it in to find out!! dont wanna ruin teh engine!CHeers againJay Quote
smythy75 Posted December 12, 2007 Posted December 12, 2007 Remember I'd like that engine in one piece when you leave it down boyo, not scattered across the UK lol!!! its all in one piece, got this gear box out yet? Quote
