stevie-m Posted June 11, 2014 Posted June 11, 2014 when i fitted one side off the c-piller it went in nicely with the back seat belt but the other side is loose i think I've damaged the threads is there any way it can be fixed ? Quote
daniel_g Posted June 11, 2014 Posted June 11, 2014 Drill and re tap could save it or you might need a helicoil insert in there aswell. Quote
daniel_g Posted June 12, 2014 Posted June 12, 2014 A threaded insert.Run it through Google, halfords do kits am sure. Quote
Gainzy Posted June 12, 2014 Posted June 12, 2014 Also give the bolt a good grease up wd40 or something see if it will screw in smoothly, I used some bolts out of a saxo a while back which did the job as pretty much all euro cars have the same threads Quote
stevie-m Posted June 12, 2014 Author Posted June 12, 2014 thank you all ill have wee look in halfords cheers bud gainzy ill give that a try aswell see if it also works Quote
