JamesD89 Posted June 13, 2014 Posted June 13, 2014 As above people, mine is finally fucked. Thanks in advanceJames
JamesD89 Posted June 21, 2014 Author Posted June 21, 2014 Anyone? Terrible time of year not to be able to open the window
JamesD89 Posted August 10, 2014 Author Posted August 10, 2014 Bump Did have one sorted but My Hermes did not fancy delivering it to the address written on the parcel Would also consider a working uk spec ep91 motor and assembly. James
H_D Posted August 14, 2014 Posted August 14, 2014 Got one. Pm if interested Ep91 wont fit unless if u chop wires and soldier
Ersel Posted August 14, 2014 Posted August 14, 2014 Mr2 ones also fit just gotta swap plugs cheaper to:) i changed both on my ep82 for them worked perfect
JamesD89 Posted August 14, 2014 Author Posted August 14, 2014 Got a glanza oneAs above mate Glanza will not fit but uk spec will if the plugs are swapped over as they use the same motor apparently. Thanks anyway. Got one. Pm if interestedEp91 wont fit unless if u chop wires and soldierPmd
