Im having problems with my glanzas idle.
when i first start it from cold it idles around 1400rpm and once it warms up the idle stays on 1100rpm.
what can be the cause? Ive checked for air leaks and cannot find a leak.
Anybody know?
Thanks
Sounds like the idle up valve on the end of the inlet is playing up. As the idle drops when warm so that would suggest the wax stat in the throttle body is working.
Ill unplug it and see what happens.
its also forged can that be a cause for it?
Edited by mr_K
If your idle control valve is broken, you will get a stable high idle between 1000-1200, because the valve is leaking all the time. Unplugging the connector won't help as the copper thing keeps it shut and solenoid opens it when needed.
Where can i get a replacement idle control valve?
I need this sorted because the petrol consumption is bad.
thanks
Lol..
im going to try get hold of a used one and hope that its not faulty.
Cant i run my car without one?
Take it off and block the hole on the intake mani?
