fordie_glanzaV Posted July 6, 2014 Posted July 6, 2014 Looking to get 3 bar map sensor for my emb very soon. I know the greddy 1s are over £100 new. Got a link sent to me for a cheaper option. Has anyone had bad experience with the cheaper replicas.I know rob_bower wouldnt of linked me to it if he had problems with it.. Is it get what u pay for or just paying for the name... Any help be much appriciated. Quote
triple j Posted July 6, 2014 Posted July 6, 2014 i no u can use the gm 3bar sensors to work, have a look about them. Quote
Phil Posted July 6, 2014 Posted July 6, 2014 never had an issue with the cheap chinese 3bar one. i have had the toyota one fail/leak pretty sure the toyota/denso will be ten times better built (at the time) but these things happen. id have no problems using one again. Phil Quote
fordie_glanzaV Posted July 6, 2014 Author Posted July 6, 2014 i no u can use the gm 3bar sensors to work, have a look about them. Yeh heard few people say about them. But never looked into it never had an issue with the cheap chinese 3bar one. i have had the toyota one fail/leak pretty sure the toyota/denso will be ten times better built (at the time) but these things happen. id have no problems using one again. Phil Cheers phil aslong as people have used them and they been ok. Way i see it i could buy a few for the price of a genuine 1. Lol. Might bite the bullet and get 1. Cheers again lads Quote
TurboTobz Posted July 6, 2014 Posted July 6, 2014 Engine rebuilds are more expensive. Why run the risk?Save £85 if it's inaccurate you'll cost yourself a lot more... Quote
Gainzy Posted July 6, 2014 Posted July 6, 2014 Engine rebuilds are more expensive. Why run the risk?Save £85 if it's inaccurate you'll cost yourself a lot more...Take note! Quote
Stu Posted July 7, 2014 Posted July 7, 2014 The genuine GM units are very good and are commonly used in high power setups - just make sure your buying a 3/5bar unit when bidding for any off ebay etc. The part numbers will tell you which version it is. Quote
Stu Posted July 7, 2014 Posted July 7, 2014 Here's a website you can use to reference the part numbers against: http://www.robietherobot.com/storm/mapsensor.htm Quote
