Ep82 roof light issuse
Hey guys
Need to know why my roof light on my ep82 doesnt work when opening the door
If i turn the switch to on it will but not when doors open on the door setting.
Also if i was to wire a boot light in where would be best?
Hey guys
DOors is probably a faulty door switch. DO you get the door light on the dash?
Also the best place for a boot light is probably in the boot ;)
  • 3 weeks later...
Well theres a small update on this.
The door light on still doesnt work the light pops up on the dash to say the doors are open.
Also the illiumated key barrel lights up apon door opening ect.
roof light works in the on postion yet just not when the doors open.
Once I figure this out I will tackle footwells and boot light
  • 3 weeks later...
781DA208-A874-48E5-AAF8-C9FC19B0E95A_zps
If you have power up to the socket then it's the rivets I found to be the problem. Get a flat head screw driver and scrape around them to get a good contact again.
You will need to do both sides of the rivets
Edited by turbo Grant
