spoon Posted July 18, 2014 Posted July 18, 2014 hi just wondering if it possible to pop a stock paseo 421 manifold on my stock glanza s? if so will i have to mess about with the standard exhaust or is it a bolt on bolt off job? because i'd rather not start cutting and welding the original exhaust! Quote
richardc9052 Posted July 18, 2014 Posted July 18, 2014 I don't know if that's the same but I've just modded a 4-2-1 mani off an ae111 20v with full custom 2" stainless exhaust and the difference is massive when paired with a tubular corolla mani!!! Quote
spoon Posted July 18, 2014 Author Posted July 18, 2014 thanks, so i'm guessing i'll need to modify the exhaust to fit the flange but is it the same size as the stock one? Quote
glanza s ep91 Posted July 31, 2014 Posted July 31, 2014 I don't think its the same size, I had one fitted but had the rest of the exhaust made the same time so could'nt compare but since its made for a 1.5 It would imagine it will be bigger. Quote
FMuscle Posted August 24, 2014 Posted August 24, 2014 I can mesure them diameters tomorrow at work, I have both 5E and 4E stock collectors. 5E laying in the shop and the 4E still doing its job Quote
Sudden Posted August 27, 2014 Posted August 27, 2014 I took the entire exhaust off my sera (4-2-1)cast header etc and installed it on my 4e. The flange where the 4-2 joins to the 2-1 touches the block by the front lower 17mm gearbox bolt. I managed to get away with cutting a notch out of the flange. Massive improvement over the giant catalytic converter from the 1st gen 4e. Quote
