Specs are:
4efte/4efe/5efe
Intake opening: 2 DEG BTDC
Intake Closing: 42 DEG ABTC
Exhaust Opening: 38 DEG BBDC
Exhaust Closing: 2 DEG ABDC
Intake Lift: 7.2mm
Exhaust Lift: 7.0mm
Intake Duration: 2+180+42= 224 DEG
Exhaust Duration: 2+180+38= 220 DEG
5efhe
Intake opening: 4 DEG BTDC
Intake Closing: 56 DEG ABTC
Exhaust Opening: 46 DEG BBDC
Intake Lift: 8.0mm
Exhaust Lift: 7.3mm
Intake Duration: 4+180+56= 240 DEG
Exhaust Duration: 2+180+46= 228 DEG
Edited by mech5107
this is the Information i got:
high of the cam
4E-FE IN.: 40,8mm EX.: 41,0mm
5E-FE IN.: 41,5mm, EX.: 41,2mm
4E-FTE IN.: 41,5mm, EX.: 41,4mm
5E-FHE IN.: 42,7mm, EX.: 41,9mm
but maybe there are differences between the german and the uk spec, starlet???
high of the cam
What are those numbers?
x2 where are those measurements from/to @Motion?
Phil
  • 7 years later...
On 7/20/2014 at 10:50 AM, motion said:
4efte and 5efe got slightly more lift then 4efe
Our German friend got it right. This is the same as I'm finding. Thw the measurements differ some what.
From what I'm reading here and on the aussi video there does seem to be different Sera cams (5ehfe) maybe different models or age related.
Edited by Sam44
