Duduglanza Posted July 25, 2014 Posted July 25, 2014 What are these pipes for? I changed my throttlebpdy therfore i cannot use them anymore. What should i do with them? Loop them or just leave them open? Quote
mech5107 Posted July 25, 2014 Posted July 25, 2014 Put one before the throttle body and one after.If you don't, the when on idle you turn the wheel, the rpms will drop significantly. Quote
Duduglanza Posted July 25, 2014 Author Posted July 25, 2014 I dont have any place to fit pipes in ny throttle body... just from the plenium.. Quote
mech5107 Posted July 25, 2014 Posted July 25, 2014 As I wrote previously, one pipe to a nipple after the tb, so to the plenum and the other before the tb, so either in your piping or could let it in the open air. Quote
richardc9052 Posted July 25, 2014 Posted July 25, 2014 As above, just use two random vac ports. I did have mine looped and it worked fine but on a cold day it can cause them to stall Quote
mech5107 Posted July 25, 2014 Posted July 25, 2014 Just to be safe, one goes to vaccum one goes to atmospheric air Quote
Stu Posted July 25, 2014 Posted July 25, 2014 You can run without them, just set your idle slightly higher at say 1000rpm so it doesn't stall if your turning at idle (not often) Quote
