FrozenJakalope Posted August 2, 2014 Posted August 2, 2014 (edited) Hey Anyone got any experience of these? Guessing I could install one easy enough using the tacho wire behind my current N/A, non-tacho-having clocks and bolt this to the pillar, saves the effort of getting new clocks and switching the odometer over and fucking with the wiring in the plugs and so on. Thoughts? Josh Edited August 2, 2014 by FrozenJakalope Quote
5e colin Posted August 3, 2014 Posted August 3, 2014 there easy installed mate take feed from ecu pin or dizzy signal there is few options of doing it Quote
littlegreenmonster Posted August 6, 2014 Posted August 6, 2014 On the n/a there is a little box on the fire wall in the engine to the righg hand side, put a spade connector on the wire drag it through plug it it, ta da tacho time !!! Quote
FrozenJakalope Posted August 7, 2014 Author Posted August 7, 2014 Cheers for the advice lads, I'll see how I get on when it gets here. Love the free delivery from China, might just get it this side of September.Josh Quote
FrozenJakalope Posted August 15, 2014 Author Posted August 15, 2014 Update on this, got it in and working using the tacho wire from the back of the standard clocks (still can't help but feel it would've been easier to put a tacho in as standard, but what do I know?), and the power from the back of the ignition fuse. Used the diagnostic port to test it first, but I didn't want to run the wire through the firewall, this way all the wiring is hidden in the dash Quote
littlegreenmonster Posted August 23, 2014 Posted August 23, 2014 What wire is the rpm wite dude ?? Im hoing to change mine because it is unused in mine to bud Quote
FrozenJakalope Posted August 25, 2014 Author Posted August 25, 2014 (edited) There's 3 plugs on the back of the clocks, the one you want is on the far right as you're looking at the dash, nearest the door. From the end of the plug, there's 3 wires in a row, then 2 missing, the next one is your tacho signal, 6th one in. Edited August 26, 2014 by FrozenJakalope Quote
