I noticed I have 2 missing fuses in the fuse box under the steering wheel on my glanza s.
The missing fuses are ECU-B 5AMP - IGN 5AMP.....Should they be in there or is it ok to run the car without them.
car drives fine tho only noticed it today.
Edited by spoon
they are not needed, if you look closer at the ports where the fuses are missing there will not be any connectors for them anyway.
