Can any one tell me if this is sitting ok or not. I have mounted it but seem to hang low on the side if you look at the picture.
Edited by jamesh
Its not sitting correctly and neither are the lights,
Looks like the car has front end damage for the lights not to line up and the bumper to hang low.
Edited by H_D
Worth bearing in mind that replica's never fit correctly anyway, a lot of members have found that with id workz items, no offence intended....
Probably the mounts.
The OEM 98 spec slots under the lights. Mine never sat right when i bought my old glanza. But, after abit of fathing with the lights and when i put it on/off a few times i got it right... Unsure if an orginal VARIS is the same.
But might be worth trying to lift up and push in under the lights slightly?
I will give that a go later on today. But I think the mounts under the lights are lower then they should be will see if I can adjust them some way
just look at the way the indicator sits next to the headlight its not straight its obviously had a hit before.
No the indicator bracket snapped where you screw it on to the body I had to use a zip tie to keep it in place
Edited by jamesh
