string Posted December 26, 2007 Share Posted December 26, 2007 size?width?and how low?need sum ideas or u could answer.16s x 7" wit 40mmm rub or not?many thanks string Quote Link to post Share on other sites
Guest Enzo Posted December 26, 2007 Share Posted December 26, 2007 the answer to your question yes it will rub slightly on your drivers side,because of the suspension set up(panhard rod) when you lower an ep the whole beam shifts ever so slightly to the right(drivers side)im only talking mm's here, especialy with a 40 drop, so you might have slight rubbage. to get around it, a cheap fix would be to buy a rubber hammer and pound the lip back, the more expensive fix would be to invest in an adjustable panhard rod that realines the beam ps get 16s !! Quote Link to post Share on other sites
vineygt Posted December 26, 2007 Share Posted December 26, 2007 14's with a 130mm drop...on a 106 tho lol Quote Link to post Share on other sites
rob_bower Posted December 26, 2007 Share Posted December 26, 2007 15"'s with 195/50 tyres although the offset is a little larger than recomended so they do catch a little over larger bumps but fill the arches out much better!! Still on the original tte springs so 25mm lower than standard!! Quote Link to post Share on other sites
Liam_D Posted December 26, 2007 Share Posted December 26, 2007 Was on 15''s with 195/45 tyres and a 40mm drop and it was fine. Although it was on 16''s with 195/45 tyres and a 40mm drop before that and it rubbed like mad on the rear and caught the inner arches on full lock.Is currently on 14''s with 185/55 tyres and a 40mm drop and it drives perfectly. Quote Link to post Share on other sites
Nanglebadger Posted December 26, 2007 Share Posted December 26, 2007 was on 14s with a 40mm drop...then 17s...now 15s still with the 40mm drop...but I've ''ordered'' some 14s!!!! ;) Phil. Quote Link to post Share on other sites
whitestarlet Posted December 26, 2007 Share Posted December 26, 2007 currently 14's but thats gonna have to change to 15's or possibily 16 but i will need to look into that more Quote Link to post Share on other sites
montanajr Posted December 27, 2007 Share Posted December 27, 2007 15"x7J with 195/45 on the front15"x6.5J with 195/45 on the rearWith Tein springs. No rubbing, goes well! Quote Link to post Share on other sites
Sparky Posted December 27, 2007 Share Posted December 27, 2007 14's with a 130mm drop...on a 106 tho lolI want to see that 16x7'sLowered 60ish at the moment but going lower on the back Doesnt rub at all on the back offset is spot on although its rubs slightly on full lock the one way and catched the outer arches when cornering at speed but my wider fenders and spacers will cure that ;) Quote Link to post Share on other sites
vineygt Posted December 27, 2007 Share Posted December 27, 2007 its a nightmare to drive, slightest uneven road and it scrapes handles like you wudnt believe though Quote Link to post Share on other sites
