Mine did. Was a zisco supplied one but same as universal ones from eBay. Did a leak test on the dyno a leaked badly from both sides of the shaft. Couldn't map the car so took it home and out the standard one back on.
I cannot put the standard back on.. flanges don't match. I have seen a couple of cars using these throttle bodies. I dont know what they have made on them to fix it :(
I managed to take everything off and checked deeply for leaks.. i tightened all fitting and put everything back on. Now idleing fine... altough the tb leaks a bit from one side to another it didnt effect. To idle it still needs a slightly gap or else it will choke.
