Can some one show me a sportif with 15s on and standed ride hight also is there any other way of lowering my car without having to fork out for a adjusteble panard rod ? Can you just add a spacer to the side that's in too much ? Sorry I'm a newbie to lowering anything with a panard rod :/
It depends on how much you lower the car by. My previous GT was low enough for the tyres to be in the arches which caused a problem as it moved over. However I've recently done my new GT and it's not really changed how the axle sits... It's lowered about 40mm...
-40mm is fine but you will see the difference if your looking for it. I have mine lowered without adj pan hard rod and it doesn't rub.. Also depends on wheel width, offset and tyre sizes
