FMuscle Posted August 27, 2014 Posted August 27, 2014 (edited) Hi, I have been looking all over the place for an inlet insulator for my 5E. No luck until I found this guy in USA who made them for a Tercel board. But, after a few emails, he does not have any left in stock, and cannot produce any more of them.So my question is, do any of you have:one lay around you don't use;material and equipment to make one;a link to where I can get one?I'm looking at either one of the lower 2 shapes on this pic:Thanks in advance. Edited August 27, 2014 by FMuscle
fremyjay Posted August 27, 2014 Posted August 27, 2014 (edited) The 4-efte ones came in two different sorts, one had a hole like the bottom one in your picture and one same as second one in pic, you can get them brand new from id-workz or i have one that was wrong for my engine never fitted i can send which is same as second one and from id-workz, they are £16 new so could do it for £5 plus postage if not they are known as inlet manifold gaskets over here so if you search google then you should find loads of places that do them Edited August 27, 2014 by fremyjay
FMuscle Posted August 27, 2014 Author Posted August 27, 2014 Just to be clear, the pic shows gaskets, it is for shape reference only. I'm after a an insulator, which is about 5mm thick, and comes alone or in a kit with gaskets and longer bolts, like this:
TrisK Posted August 27, 2014 Posted August 27, 2014 Just to be clear, the pic shows gaskets, it is for shape reference only. I'm after a an insulator, which is about 5mm thick, and comes alone or in a kit with gaskets and longer bolts, like this:Racetech do a thermal inlet manifold gasket
fremyjay Posted August 27, 2014 Posted August 27, 2014 My bad, I thought you were talking about a gasket as in the photo above
