I have just purchased a greddy emanage ultimate ecu, i am capable of installing it myself but was wondering if anyone had a wiring diagram? If not if anyone knows of anywhere closest as possible to me in Norfolk that would be able to install it and map it?
Thanks in advance
Harry
I wired my emanage blue in and there won't be much difference between the blue/ultimate. i also made my own main harness and ignition harness and cost me around £12 with the cable and connectors. There will be wiring diagrams knocking around on google its just having the patience to look for a little bit. :thumbsup:
Thanks bud did you get another standard ecu harness to modify to make up a harness for the emanage or did you make one from scratch
