1990timeismoney Posted September 1, 2014 Posted September 1, 2014 Hi all looking for an actuator for the td04.not sure which is best either a td04 or a ct9 hks any advice or one available would be great.Also looking for the bracket to hold the actuator if there still available. Thanks
5e colin Posted September 1, 2014 Posted September 1, 2014 i have 1 ere adjustable , got it a few months back 35£ ready to bolt on
aaddzz123 Posted September 2, 2014 Posted September 2, 2014 I used a ct9 hks actuator and bent the bar a bit then make a bracket to fit it. Bit of effort but works a treat and looks tidy.
richardc9052 Posted September 2, 2014 Posted September 2, 2014 I have a standard td04 one here.. Adjustable too which we should have had in the ct9 as standard
1990timeismoney Posted September 2, 2014 Author Posted September 2, 2014 Appreciate the replys guys for some reason I've got big fittings on my oil feeds that takes up most of the room for a bracket hence why at the moment it's not at the standard I'd like.was hoping one of the rw brackets were still available as there thin and should fit easy into the space
