ok i have a real problem when manovering slowly or turning i get some serious engine jumping/ knocking i thought it was because of a flat spot in the tyres but got new ones today it is still jumping/ knocking. this happens especialy when turning. any ideas ?
My current car does that when im turning and someone told me my brushes need replaces where the joints are for the steering or something?
sounds like it could be a c.v joint or as said could be a engine/gearbox mount away best way to check for engine mounts is to use a pry bar and see if there is any excess play in the bushes.
or it could be that you have an lsd gearbox as they do jump and knock going round corners which is normal.
