jellybaby Posted September 9, 2014 Posted September 9, 2014 (edited) hello guys I currently re installing my loom however it was over 2 years ago it was removed lol I connected 99% of connectors up just have to left which are basicly a long piece of the loom with two white plugs on it looks like it ment to run down the handbrake I will get a pic 2 moz when its light Edited September 9, 2014 by jellybaby Quote
Scoobysvx Posted September 10, 2014 Posted September 10, 2014 If you can provide an email address or what'sapp I can send the ones through which I took when I converted my 4paw... I'd imagine I've got what you after as I took load for my own reference! Quote
TimD Posted September 10, 2014 Posted September 10, 2014 Might find this PDF useful http://www.mearcat.com.au/docs/EP82%20Starlet%20Wiring%20and%20Connectors.pdf Quote
Scoobysvx Posted September 10, 2014 Posted September 10, 2014 Why was this not about when I was doing mine 😩 lol Quote
jellybaby Posted September 10, 2014 Author Posted September 10, 2014 Very useful link must be sticky Quote
jellybaby Posted September 10, 2014 Author Posted September 10, 2014 Might find this PDF useful http://www.mearcat.com.au/docs/EP82%20Starlet%20Wiring%20and%20Connectors.pdfdo u reckon he did a ep91 one as I have ep91 Quote
TimD Posted September 10, 2014 Posted September 10, 2014 Unlikely, hopefully most of the plugs are similar. Quote
daniel_g Posted September 10, 2014 Posted September 10, 2014 I take it this isnt part of the loom which runs down the O/S door sill ? Aslong as the rear electrics work and the fuel pump connector are in i wouldnt worry too much, ive found starlets have lots of spare plugs, most are taped away for optional amps and other random shit behind the dash. Quote
jellybaby Posted September 10, 2014 Author Posted September 10, 2014 I have a white connector in the os loom which I can't find where to plug in to. All the collom plugs are in just can't locate where to connect the loom on the os sill to the dash loom lol Quote
daniel_g Posted September 10, 2014 Posted September 10, 2014 I have a white connector in the os loom which I can't find where to plug in to. All the collom plugs are in just can't locate where to connect the loom on the os sill to the dash loom lolInto the ABS ECU maybe ? Quote
jellybaby Posted September 10, 2014 Author Posted September 10, 2014 could do but I removed the abs loom from the car as has no abs and the control unit been removed but I still got it in my tool boxbut I not sure if the abs control unit also powers the rear lights and fuel pump etc Quote
daniel_g Posted September 10, 2014 Posted September 10, 2014 could do but I removed the abs loom from the car as has no abs and the control unit been removed but I still got it in my tool boxbut I not sure if the abs control unit also powers the rear lights and fuel pump etcTheres 2 multiplugs which go into the ABS ECU, one is attached to the loom that runs from the ABS module through the O/S wing and into the ABS ECU, the other multiplug is attached to the dash loom and runs up the O/S for a foot or so into the ABS ECU.Nah the fuel pump and rear lights etc arent connected to that. Quote
jellybaby Posted September 10, 2014 Author Posted September 10, 2014 my whole abs wiring is removed lol so deff not there so I just will have to wait till morning the I will use my volt meter and see if the connector I have spare on the os of the car which looks like it runs the rear light and fuel pump etc act does if it does then god knows where it goes to should of labled them better lol Quote
asbo-v Posted September 10, 2014 Posted September 10, 2014 Rear abs loom that runs with back loom to rear sensors they came through the rear seat section to front through a gromit I'm sure both sides have it dont remove it thou need them for future ;) Quote
jellybaby Posted September 11, 2014 Author Posted September 11, 2014 that is the loom i have no idear where or what it plugs in to lol the loom on the os we was talking about is the abs loom for the rear etc. the light etc and pump run from the gray plug situated behind the dash next to the engine loom connectors Quote
