That green bar that goes from top to bottom on is always flimsy but your slam panel has had the catch ripped straight off it with the left and right bolts
Edited by Glanza-Ben
X2 what Ben said. The part you require is bolted to the top cross member but yours looks Asif it's been ripped out. You require a new slam panel aswell mate hope this helps :)
easy to fix or?
thanks guys
The slam panel is welded on I believe
I would try and weld a plate where it's ripped out of then drill new holes in it
Or take the vertical bar out completely along with the bonnet catch and just stick bonnet pins in or aero catches to secure the bonnet.
