SOLD - RW-Developments TF035 Top Mounted Turbo Kit/FMIC/Exhaust
RW-Developments TF035 Top Mounted Turbo Kit/Exhaust
This was custom built by Dean for a friend of mine who has since parted with his car and got out of the starlet scene.
The kit uses a TF035 Turbocharger, which has a slightly smaller Exhaust wheel to a TD04L.
Meaning Faster spool but yet nearly making the same power (about 10bhp behind a Stock TD04L & Spools around 900-1000rpms Faster)
This kit is good for 240bhp on a 4E-FTE at 1.2bar!
The front (bumper exit) exhaust is silenced with a 12" silencer. Meaning when cruising it is actually silent (no exhaust under car to rumble and drone) but becomes very rawcus on boost.
The Wastegate is fitted with a 0.3bar Spring. Different spring or some form of boost control would be required to increase from there.
The kit consists of:
RW-Developments Top Mounted 2-Bolt Externally Gated Manifold
RW-Developments Front Exit Silenced Exhaust/Downpip w/3.5" Outward Rolled Tip
TF035 Turbocharger, Welded Wastegate Port & Rotated Core (Came off a low mileage forester, no smoke, boosts nice!)
RW-Developments Screamer Pipe
38mm External Wastegate Red
RW-Developments Backdoor Front Mounted Intercooler Kit (1 Joiner From Turbo/1 Boost Pipe Coldside)
Subaru MLS Turbo & Downpipe Gaskets
Tial MLS Wastegate Gaskets
Race-Tech Stainless Braided Oil Feed Line & Banjo Bolt
Roose Motorsport Silicone Oil Return Line
Ill include all nuts, bolts, clamps, fitting hardware.
The fab work on this kit is stunning. Dean is very talented and Id recommend his work to anyone.
post-2707-0-05565300-1412587308_thumb.jp
Small video here:
http://youtu.be/ZlJsSTsTxD8
Note. No Smoke. Nice Crisp Turbo Sound. No Blowing or Anything.
Sounds louder then it is in video also...
Price:
£1100 Posted
Current Location:
Lincolnshire, UK
Payment & Postage:
Postage Via Private Courier
  • 2 weeks later...
