Camskill not got any ??
Yea cams kill have got some just can't believe the price jump
It's £49 for after 1992 ep82 then jumps to £139 for pre 92
I had some 1mm spigot rings here i made but i think the discs are also smaller on the early models.
I can see if i can find them if you want. You could always upgrade caliper carriers and use bigger discs then too
I can modify the 254mm diameter / 55mm bore WMS 110% discs so they come with 54mm rings fitted (assuming the 54mm GT caliper takes the same disc dimensions as the EP91 does) - adds £35.00+vat/pr making them £100+vat/pr.
Any help? :-)
Can do grooved and (probably) pads etc too.
Any help? :-)
This could be an option want me to measure the disc I took of so we can be 100% sure
