Car has developed a misfire under full boost randomly, not sure why, here is a video of what it is doing
>http://youtu.be/p_ICf3b1tnc
Any ideas?
My glanza done the same and I changed plugs, plug leads, rotor arm and distributor and made no differences so then I changed fuel filter and run injector cleaner thru it and seems to be ok now
I had a miss fire once on me starlet.
was a corroded and split coil pack.
I would be going back and checking dizzy cap and rotor arm and plugs also.
As above though had an ignition overhaul within less than half a year
