karl. Posted October 28, 2014 Posted October 28, 2014 Does anybody know what the clearance is on a standard 5efe engine with a 0.5mm head gasket? Even 4efte with a standard gasket would be fine I'm hopeing to build a high compression 5e engine but I want to keep it non interference. I will also be using high lift cams so I will need to add a extra 1mm or so to the valve opening.Any info is appreciated. Quote
5e colin Posted October 28, 2014 Posted October 28, 2014 fyi i buillt a 5efe with gen1 pistons with dec scimmed and head scimmed and o.5mm gasket from toyota and didnt touch Quote
karl. Posted October 28, 2014 Author Posted October 28, 2014 That's a good start Colin thanks, I will be skimming the deck along with the head and using wiesco 10cc pistons so going by that I shouldn't have any problems Quote
Phil Posted October 28, 2014 Posted October 28, 2014 (edited) 4efte0.6trd Block deckedHead skimmedStock cams10cc dished wiescoInterference Edited October 28, 2014 by Phil Quote
Phil Posted October 29, 2014 Posted October 29, 2014 Check this out. Especially teds commenthttp://www.toyotagtturbo.com/forums/showthread.php?97661-Non-interference-engine-proof&highlight=Interference+valve+WeejohnAnd this, note texx contributionhttp://www.toyotagtturbo.com/forums/showthread.php?101103-what-s-minimum-space-between-piston-and-head&highlight=Interference+valve+WeejohnPhil Quote
Sudden Posted October 29, 2014 Posted October 29, 2014 (edited) http://instagram.com/p/q0Ks-oN9J7/ 5e-fe, 4e-f pistons, 0.6mm dis head gasket, skimmed head, 5efhe cams. Plenty of clearence.Intake: 0.118in / 3mmExhaust: 0.196in / 5mmInteresting to note. The 5e-fhe pistons have a larger valve relief than all the others. Edited October 29, 2014 by Sudden Quote
karl. Posted October 30, 2014 Author Posted October 30, 2014 (edited) http://instagram.com/p/q0Ks-oN9J7/ 5e-fe, 4e-f pistons, 0.6mm dis head gasket, skimmed head, 5efhe cams. Plenty of clearence.Intake: 0.118in / 3mmExhaust: 0.196in / 5mmInteresting to note. The 5e-fhe pistons have a larger valve relief than all the others.Thanks very much for that, it helps a lot.Here's the picture for anybody that can't see it. Edited October 30, 2014 by karl. Quote
