Whitenoize Posted October 30, 2014 Posted October 30, 2014 (edited) Ok so I'm wiring in my turbo timer I'm useless with electrics but I'm to tight to pay sumone to do it for me I've had a hunt around and it seems straight forward anuf only thing is one wire connects to the O2 sensor signal from the ecu am I rite in thinking this is the oxygen sensor ( lambda sensor as in no10 on this wiring diagram ? Just want to confirm before I start splicing into wires Edited October 30, 2014 by Whitenoize Quote
5e colin Posted October 30, 2014 Posted October 30, 2014 go ahead with your idea but is it a cheapo timer that reads afr ???? if so its totally useless mate and no where near real afrs Quote
Whitenoize Posted October 30, 2014 Author Posted October 30, 2014 It's an stri one from td any point in connecting it up to the 02 sensor ? Quote
Whitenoize Posted October 30, 2014 Author Posted October 30, 2014 Why you need afr signal for turbo timer? it's a feature on the timer I know I don't need to connect it for the timer to work but thought I mite aswell use it if it's on ther Quote
JayJ Posted October 30, 2014 Posted October 30, 2014 it's a feature on the timer I know I don't need to connect it for the timer to work but thought I mite aswell use it if it's on ther Ahh, it has a feature to show the narrowband afr : ) Quote
Whitenoize Posted October 30, 2014 Author Posted October 30, 2014 Yes mate is that the correct wire I need to splice into no10 ? Quote
JayJ Posted October 30, 2014 Posted October 30, 2014 Yes mate is that the correct wire I need to splice into no10 ? Yes it is Quote
