Well after searching for an OEM LSD Box without any hope i'm now thinking it may be better just to get a LSD and fit to my gearbox.
Where did you buys purchase yours?
Can you get any good deals from buying outside the UK? Japan ect?
Cheers,
Charlie
Remember if it's a non lsd box you can't just fit a lsd into one
Why not? So you can't fit a Cusco Lsd into another gearbox which is non-lsd?!
Aamir
Aamir
the gearbox casing is different. That's why you have the short shaft, because the case is fatter
No1 makes an aftermarket gearbox for a starlet, you mean the diff inside the gearbox which is aftermarket
Aftermarket diff not gearbox bud, That's what I meant
Aamir
