Just got one for a daily its a 98 was wandering if it did the following
Glanza ecu as its a triple plug ecu
Gt injectors
Ct9
Gt map sensor
Would it run ok?
thats the gen2 4efe so stick to 8 psi to be safe mate , just weld oil return to existing sump source a 4efte thermostathousing for water feed to ct9 also 4efte sensors must be adapted to your current manni or swap over to 4efte manni and tb
you can keep using the na clutch for a while till you can sours 4efte clutch fly
also this is a must knock sensor MUST be tapped in the block and fitted
if you want to keep your rolla loom then repinning is required and some wires added for knock external coil/igniter ait sensor because i think rolla does not have it
you need 4efte dizzy to and wires layed in your loom to run it
i think it easyer to fit complete v loom
Edited by 5e colin
Ive got one for a daily aswell, often think about boosting it. Ive a VF10 here that would be great for it :)
Do Glanza engine ancillary looms unplug from the fusebox like GT ones do ?
