brake Shoes for rally car
  • 4 weeks later...
Drums are normally the most torque you'll get for a given size (as the friction is all nearly at the outside diameter which in effect gives you a longer "lever") and as many drums are self-energising (which uses the rotation of the drum to increase the force on the shoe for "free", similar to how a servo creates extra line pressure using the "free" manifold vaccum).
In fact if drums didn't overheat so easily they would probably have remained the best bet for the front too - but they do overheat hence the disc brake.
Sort version - drums give you the most power for a one-off event like hitting the handbrake! :D
