5e colin Posted November 16, 2014 Posted November 16, 2014 hey lads wich forged rods allow stock pistons to be used ????? Quote
gorganl2000 Posted July 2, 2017 Posted July 2, 2017 did you ever find any information on this combination 5e colin? Quote
5e colin Posted July 2, 2017 Author Posted July 2, 2017 nope not really as the 1s used there in ireland eventually the gudgeon pin area had isseus started getting noisey its almost impossible to get pres pins to work in a sliding pin piston as the tolerances are out of sync Quote
gorganl2000 Posted July 3, 2017 Posted July 3, 2017 figured by now someone would have made something...guess its the bigger 4efte/5efhe rods then for those seeking to keep stock pistons Quote
daniel_g Posted July 3, 2017 Posted July 3, 2017 Why would you want to keep stock pistons?The ringlands are shite. And forged pistons can come in any CR you want.If the aim of it was to keep stock CR. Quote
5e colin Posted July 3, 2017 Author Posted July 3, 2017 This topic was started 3 years ago Daniel was looking into press to slide never went anywhere Quote
gorganl2000 Posted July 5, 2017 Posted July 5, 2017 Why would you want to keep stock pistons?The ringlands are shite. And forged pistons can come in any CR you want.If the aim of it was to keep stock CR. actually daniel_g, this is something i was interested in from years ago as well. I actually never had any problems with stock pistons (broken ringlands) in all my years. It was always the stock rods that had me a little skeptical in terms of revs and reliability at higher boost levels. Again, knock on wood, the stock thicker 4efte/5efhe rods worked great for me, but i was more concerned that a rod would give out than a piston. The stock units can work well once you have a very good tune....the tune is where it is at as the slightest detonation and your stock pistons will be destroyed at higher boost levels. as well, forged pistons you are looking at may be US$500 for a decent set, while forged rods are may be US$250 for a set----depends on your budget and what you want from the car. Quote
