Adeeb1395 Posted November 25, 2014 Posted November 25, 2014 I hv a 5efhe engine installed in my car with 4efte inlet manifold,throttle, fuel rail etc.Want to do 5efte.so bought a 4efte donor engine.The other parts i hv collected isTdo4 turboAem fic6Fmic and pipingi would like to use the fhe internals with 4efte pistons.also want to boost 7psi atleast and 1bar max.Do i need any other parts than 550cc injectors and fuel pump?or should i do high comp turbo?Thanx in advance. Quote
Stu Posted November 26, 2014 Posted November 26, 2014 With 4efte pistons on 5efhe rods you'll be fine at 1bar as long as the tune is good. High comp will also be fine as long as the tune is good - I have had several 5efte setups using stock internals myself - just conservative timing and don't rev them too hard (ie limit around 7500rpm). Injectors wise 550's would probably be slightly overkill but if you have them, use them. Gives you more scope for improvements later on. Quote
Adeeb1395 Posted November 26, 2014 Author Posted November 26, 2014 Do i need to go forged internals if i dont use fhe rods? How much boost iy can manqge if i use 5efe rods only? Quote
Stu Posted November 26, 2014 Posted November 26, 2014 Ah, yeah 5efe rods are a fair bit smaller - I have run a stock 5efe with a hybrid vf10/ct9 turbo on stock ecu before without any issues but only 12psi boost. It ran like that for years and the engine ended up in another car and last i heard was still going strong. Key thing is the tune - needs to be conservative timing and rpm limit if you want to run lots of boost. Ideally a 5efhe rods/4efte pistons combo would handle what you want to achieve. Quote
glanzatd04l220 Posted November 27, 2014 Posted November 27, 2014 I've'e a set of 5efhe rods for sale if your looking a set. kevin Quote
