Hi All, just a quick check if I can remove the two rubbers at both ends of the slam panel, obviously without doing any damage to both rubber and panel. Below is a picture of the rubber.
Thanks guys :)
Thanks for the replies :), will check them out again. wanted to remove them so I can spray the slam panel (because of normal wear and tear when working on the engine).
The V is silver, any ideas what colour they are normally sprayed? was going for a normal grey colour.
Thanks again.
  • 2 weeks later...
