Kirkyyb36 Posted December 13, 2014 Posted December 13, 2014 basically been offered new clocks in km/h and as far as i know i have the mph converter. So if i buy new faces off of ebay and fit them.. Will everything work okay? Quote
GlanzaJim Posted December 13, 2014 Posted December 13, 2014 Dont see why not converter does the job Quote
Kirkyyb36 Posted December 13, 2014 Author Posted December 13, 2014 So if i put the new clocks in as kph itl work in mph? Quote
Darraghmh91 Posted December 13, 2014 Posted December 13, 2014 I thought it would of came up in mph like the setting wouldn't be right .. I'd say pm socks he might know man .. How come your goin kmp sad you use mph in the U.K. Quote
Kirkyyb36 Posted December 13, 2014 Author Posted December 13, 2014 Well i didnt realise until i watched a vid on youtube that it was kmh. But i have old dials there that i could take the faces off.. Quote
Kirkyyb36 Posted December 13, 2014 Author Posted December 13, 2014 Does the speedo converter go into the back centre of the dials? Quote
mattyD Posted December 13, 2014 Posted December 13, 2014 The speedo converter goes in the gearbox mate, well on top of it anyway! Quote
Ollieh17 Posted December 13, 2014 Posted December 13, 2014 yeh should be fine, you'll just have a speedo that goes up to 180. dont change the faces with a converter Quote
mattyD Posted December 13, 2014 Posted December 13, 2014 Do you have dials with both kmh and mph? And don't wana swap the whole cluster cuz you Wana keep the mileage on your car? Quote
Kirkyyb36 Posted December 13, 2014 Author Posted December 13, 2014 So the standard one would have 110 and the converted would have 180? Quote
morgey Posted December 13, 2014 Posted December 13, 2014 Standard non converted has 180kph or 110mph (110mph is obviously 180kph) If you have a convertor you need the 180kph clocks and need to cross out kph and replace it with mph as the convertor changes it from 180kph to 180mph. Quote
Kirkyyb36 Posted December 13, 2014 Author Posted December 13, 2014 ahhh i understand now, thanks for clearing that up😊 Quote
