right lads and ladies my clutch is slipping badly and my gearbox is crunching going into 2nd, so while im changing the clutch i want to put a 6 speed box on while im there. what car has the 6 speed box i need and is it just the gearbox i need?
kevin
there not suppost to be that strong from what i heard, and a 5 speed lsd dont fit. i was thinking of the conversion for mine, but when i read that folk with the g6 corollas were converting them back to 5 speeds
Sorry i accidently deleted your post.
What i was going to say is, it depends on the bolt pattern on the final drive 8 bolt and you can fit an aftermarket lsd to the 6 speed fine. But if its a 6 bolt diff the you would need to find a 6 bolt lsd
