Hi,
I bought a Glanza s ecu for my starlet. I know the wiring is different on both the ECU's so I want to remove the Glanza ecu board from its housing because the pinouts are most times written on the board, but somehow it's stuck. Does anyone have an idea how to remove the board without breaking it?
Or does someone has the exact pinouts for the Glanza s and stock eurospec starlet as well?
Do all Glanza S have a knock sensor though ?
Thought it was only the late spec Jap N/a starlets with the Gen3 4EFE.
The 99 Jap N/a i used to have had a knock sensor, 3 wire o2 sensor, DIS ignition system and a few other things.
I've opened 2 rivets but it still won't open. Should I also remove the 3 rivets to the ecu plugs?
Or should I only remove those 2 rivets on top of the housing, not on the board itself?
Here they come! But i think i need to remove both the rivets on top of the lid. How can this be best done so i can reattach the lid?
Pivets inside the ECU cover, already removed them but without luck:
On top of the lid:
