Tyler Posted December 26, 2014 Share Posted December 26, 2014 I've just put a 5e in my na and engine turns over, there is fuel getting to it, is my next check the spark plugs? I've tried two different dizzys and it won't start Quote Link to post Share on other sites
mikey4410 Posted December 26, 2014 Share Posted December 26, 2014 do u defo have a spark ?? Quote Link to post Share on other sites
fiddlersport Posted December 26, 2014 Share Posted December 26, 2014 Hi a bit of information on the conversion will help us get you certain answer to yuor problem, are you using the 4efe ecu or 5efe ? Quote Link to post Share on other sites
Stu Posted December 27, 2014 Share Posted December 27, 2014 If there is fuel entering the cylinders it means the injectors are pulsing so that would mean the ecu is getting power (actually just the fuel pump working is also and indication the ecu has power as the pump will only run when the ecu is sensing engine rpm). If you can hear the injectors clicking then again you will know the ecu is triggering (from pickups inside the dizzy telling the ecu what the engine position is). Assuming you have checked there is no spark at the end of the plug lead, just work your way back step by step to the coil and make sure your getting spark there. If not then it could be a coil or ignitor fault, power or earth issue or ecu issue. Quote Link to post Share on other sites
