I have a spare gearbox with cups sitting around so I might aswell put it to good use and clean it up. Will LSD just be a straight fit and run off normal driveshafts? I hope I open it up and it already has lsd lol how can you tell inside I have a rough idea of how it goes but I need alot more info!
If its a normal OEM box then yeah any aftermarket LSD like cusco or TRD etc. will fit in and use the origional shafts.
When the cups are out look through the hole, the normal OEM open diff has a rod running diagonally through it, so if its not there then should be an aftermarket LSD inside.
It's going to be like kinder surprise haha cheers for the info I will find out soon enough I want a TRD one, am not asking for much am I :D
There was a thread morgey had started with pics off all the different lsds in the boxes. Can't find it on my phone but he's the man to ask.
I remember seeing that I'm sure! Couldn't find it neither was either him or taggy
