J40k-mo Posted January 1, 2015 Share Posted January 1, 2015 Obviously I need some gauges to monitor things, Going to get oil temp, oil pressure and boostDo I need any more? The pro sport gauges look the Buisness, will they be good enough for the job? Also this might seem daft but what exactly do I need to wire all these in and what to etc.. What else do I need other than gaugesMight seem really simple but don't want to go doing it my way if there's another better way,Anyone got a tutorial? Just for somewhere to start.Any help will be great Quote Link to post Share on other sites
MARC MOSS Posted January 1, 2015 Share Posted January 1, 2015 Can we assume your car is completely standard ? Quote Link to post Share on other sites
fiddlersport Posted January 1, 2015 Share Posted January 1, 2015 start with looking at a glanza ecu diagram plenty on the old googly, sure you will have to tap into some wires if you going electronic gauges, mechanical are quite simple Quote Link to post Share on other sites
J40k-mo Posted January 1, 2015 Author Share Posted January 1, 2015 Will be fully forged but undecided on what turbo to run.. And well that will be the choice I would like electrical because it looks good haha, just don't no where to tap into things, if I'd need more sensors etc,.., Quote Link to post Share on other sites
_shaun_ Posted January 1, 2015 Share Posted January 1, 2015 I have prosports I've went for oil pressure,temp,boost and water and then I have aem wideband. Adapters to fit are easy got just say what gauges you want and someone can tell you what you need Quote Link to post Share on other sites
J40k-mo Posted January 2, 2015 Author Share Posted January 2, 2015 Is it worth having wideband? What are the benefits mate Quote Link to post Share on other sites
5T4R7ET N/A Posted January 2, 2015 Share Posted January 2, 2015 Wideband is good to see how the car is fueling,if you Learn a little about fuel ratios you will find its great info for tuned cars Quote Link to post Share on other sites
J40k-mo Posted January 3, 2015 Author Share Posted January 3, 2015 So really if I'm going to be running biggish power wideband will help me keep an eye on things a lot better?What's the best wideband kit? And I am going to get prosport gaugesCan I get them in a kit with all wires and sensors etc? Quote Link to post Share on other sites
5T4R7ET N/A Posted January 3, 2015 Share Posted January 3, 2015 The widebands gauges do come with oxygen sensors and all you need for fitting. So they are more expensive then the usual oil, water temp gauges.I think prosport do a wideband so you could have a look at that. There are plenty out there, I am using AEM and its been pretty good so far. Quote Link to post Share on other sites
