Hi I've just bought one of these and want to know should I run water lines with this turbo at around 1.3 or 1.4 bar boost tuning developments say to use them so I'm inclined to but I've heard from others not to had anyone any advice here. Also any other information people have on turbo good or bad has anyone made over 300bhp with 4e or 5e? Thanks
If I were you and were told to use them mate I would do :) with regards to performance it's currently the best hybrid td04 out there regularly hitting 300+ on a 4e bud
I would be inclined to run water lines for any turbo that costs a fair crack. When you think a standard td04 is so cheap running water lines is not worth the extra stress on you're cooling system.
