mr_K Posted January 11, 2015 Posted January 11, 2015 (edited) Im currently running a td05 turbo on my glanza and im using a 1.8mm oil feed restrictor and would like to know if its good?No smoke atall coming from turbo when in boost.Thanks Edited January 11, 2015 by mr_K Quote
5e colin Posted January 11, 2015 Posted January 11, 2015 its 1.5 mm for normal non roller bearing and 1mm for roller bearing turbos Quote
mr_K Posted January 11, 2015 Author Posted January 11, 2015 Would you suggest me to change it or 1.8mm should be okay. Quote
Rob H@RCH Engineering Posted January 11, 2015 Posted January 11, 2015 It also depends on if the turbo is water cooled or not as a non water fed turbo needs more oil to aid cooling. Quote
5e colin Posted January 11, 2015 Posted January 11, 2015 you got your full answer from rob there :) id say you be aaaalright Quote
glanzatd04l220 Posted January 11, 2015 Posted January 11, 2015 hi lads what would happen if you didn't use a restrictor in the oil feed? does a td04l need a restrictor? kevin Quote
Rob H@RCH Engineering Posted January 12, 2015 Posted January 12, 2015 theres the answer https://www.turbobygarrett.com/turbobygarrett/oil_restrictor Quote
