Yes. Just use the thermostat housing off the Glanza engine and put that on the GT one if its different. The knock sensor might be different depending on the age of the GT engine. Also make sure you have the correct inlet mani gasket because there are two types, one with a waterway hole on the timing side of the engine right at the back left corner and one without.
