Sefton-EP91 Posted February 16, 2015 Share Posted February 16, 2015 (edited) Hi guys, just a quick question, Im looking to buy a second hand EMU unit to cut down on costs with my build, i was wondering what wiring should come with it? Does it use separate harnesses for ignition and fuelling? What is needed to plug it in and get it mapped? Thanks in advance Edited February 16, 2015 by Sefton-EP91 Quote Link to post Share on other sites
Duduglanza Posted February 18, 2015 Share Posted February 18, 2015 Emu comes with universal harness unless you buy a boomslang harness that can cost around 250gbp. but a more simple way is you just buy a field harness extension and wire it in yourself. there are only around 12/15 wires. all you need is an injector adapter#2 that you can buy from rhdjapan and ready to go. Quote Link to post Share on other sites
Bean Posted February 18, 2015 Share Posted February 18, 2015 as i understood it the injector adapter was only needed on the older version emanages?? the version E i thought didnt need it. Quote Link to post Share on other sites
Duduglanza Posted February 18, 2015 Share Posted February 18, 2015 Some say you still need it some say no... If you are buying an E version try working without the adapter.. if its fine than goodluck to you Quote Link to post Share on other sites
