whitestar Posted February 18, 2015 Posted February 18, 2015 I'm about to fit a TRD lsd and I'd like to know all the essential torque settings for the nuts and bolts in and around the gearbox. Can anyone help me? Quote
morgey Posted February 18, 2015 Posted February 18, 2015 I couldnt find them when we did mine but we used a digi torquewrench to undo them and came out at 115lbft iirc So we did the same and used loctite on them aswel Quote
russ78 Posted February 19, 2015 Posted February 19, 2015 follow taggys guide you cant go wrong buddy http://www.ukstarletowners.com/topic/59358-a-guide-to-fit-an-aftermarket-quaife-lsd/ Quote
whitestar Posted February 19, 2015 Author Posted February 19, 2015 Thanks guys! Actually the box is open already, just wanted to know the torque settings as we're starting to put it back together. I'll try that 115 and hope for the best. ;) Thanks! Quote
Stu Posted February 24, 2015 Posted February 24, 2015 I usually use the highly scientific setting of 4 dugadugadugas on the big air wrench /useless post Quote
Ryan_EP82 GT Posted March 20, 2015 Posted March 20, 2015 I usually use the highly scientific setting of 4 dugadugadugas on the big air wrench /useless postLol Quote
whitestar Posted March 20, 2015 Author Posted March 20, 2015 The correct settings are 124 Nm or 91 lbft. Called Toyota info and got some scanned PDFs to my email. Also the correct way to install the LSD on the ring gear is to first heat the ring gear up in boiling water (yes, this is in official toyota documentation ). Quote
