So I got my Gt turbo on the road friday, and since driving it I noticed its severely lacking in power. Especially compared to my old GT which had no more modifications really
Feels like the turbo has no kick, and the HI/LO modes are barely distinguishable.
It compares more to my NA then my old GT
Any ideas why?
Not overly smokey or anything
It has FMIC, dump valve, air filter and thats about it, but the dump valve doesnt really make a sound
Only has standard boost gauge but it never reaches 0?
Example of lack of power, was going up a not too steep hill at 40mph in 3rd, put my foot all the way down and the car wouldnt go any faster
And before it wouldnt go past 80, just felt like had no power at all.
Quite odd to find this. Also relative to my old GT it uses barely any fuel? Good thing maybe?
Any advice or help would be great
Thanks In advance, Sam
Have u got a boost gauge? Is it building ANYTHING?
Boost Leak?
Just the standard one in cluster, it does move it just doesnt reach 0, but Its probably not 100% calibrated anymore, i thought it could be that. It does have a blitz turbo timer fitted would that give any indication as to a problem?
If the boost gauge never reaches 0 then your not hitting boost.
Check your intercooler pipes and vacuum pipes that go into turbo and solenoids.
I thought it could be vac as the BOV makes nearly no noise, just a bit of sucking/whining from intercooler
Movement below 0 is Vaccum... (IE Before you come on boost)
So your making NO Boost. If that gauge is accurate Sam...
Boost Leak, would be my first port of call! :)
I will check all the joinings tomorrow and see if there are any leaks
sounds like mine on two occasions, both times turbos were knackered
Turbo would be a good call, but does it not have any signs like smokey exhaust or some noises?
Both times for me there was no smoke, because the turbo was making no boost. It just made a whinny noise. Would have to be a big boost leak to make no boost at all
I'll have a listen to the turbo tomorrow and see what noise it makes chief
